Hamer Special pickup swap
rugby1970
Is it possible to replace P-90's on a Special with traditional humbuckers without greatly modifying the guitar? Thanks.
19 answers to this question
It's a mucho different rout. Try a set of Mojotone '56 Quiet Coil pickups instead. Thank me later.
^ This. I've twice put Dimarzio DLX Plus duets in mahogany set-necks and was VERY pleased with the results. Zero alterations or mods to make it happen. Here's one of them, an intensive 70s Deluxe restoration me and HEL Shannon did.
18740687_1696619050640272_55202042481821
I like that these basically keep the look too.
On 11/25/2022 at 12:11 PM, hamerhead said:
You could do this:
I have been considering doing this with my Hamer Artist with P90s, but I thought everybody would try to stop me because it is the 3 P90 model, and I think it is a rare bird.  I figured that I could scratch my mini-hum itch with an Eclipse.
Anyway, what brand of mini-humbucker do you recommend?
That was my gigging guitar for quite a while. I went thru a ton of pickups (those pictured are Gibsons IIRC but I tried Dimarzios, Duncans, etc), eventually landing on GFS minis that not only sounded great but are cheapcheapcheap.
3 P90 Artist? I'd put a set of Josh's Firebird pickups in there and never look back.
I had some GFS noiseless singles in a partcaster and they sounded great.  The bridge/middle really evoked the Knopfler thing quite well.
So, do I order two neck pickups and a bridge pickup?  And should I go with the two-conductor option for each pickup?  I am going to wire it up simply:  no fancy phase or parallel for me.
If you go the Gravelin route, Josh already knows what your brain wants. B) Contact him.
Hey, Hamerhead:  Out of curiosity, which flavor of GFS minis did you install--'59, Fat, or Crunchy?
That's a damn good question. I can't remember what I had for breakfast.
+1 on the GFS Minis ... I have several sets and they are def. my favorite minis that I've ever used ...
