12 string bass
I have looked at 12 string bass.net for a long time. There are some that look like quality basses, it's just that the Hamers are the only ones I have ever been able to get my hands on and play. I guess all I can do is be patient. I just hate that they're getting harder to find and the prices are going up so much.
I suggested the same thing, directly and not on the forum....buy a cheap 12ver to try out first, get the hang of it.
I used to use an A/B/Y pedal to split my single output 12ver...then switched to a crossover pedal, so I could effect just the highs or lows in separate loops, so the bottom end was still punchy.
And the clown that runs that site got nailed for writing bogus rave reviews n exchange for free gear from manufacturers...so you can't believe much of it.
He also FKIN HATES HAMER....PETERSSON...JOL...ETC..  I have multiple old emails from that jerk, slamming and talking sht behind their backs...but then suckng up to them on his site. A real phony.
He stole all the files from the old .com site to start his website. Did it while volunteering to co-mind the old site for the founder who was called to active duty fighting in Afghanistan. Nice, huh?
If you've never played one.....
It is very hard to amp a 12ver right using one amp. Most guys split the hi/low signal because the wall of frequencies produced by a 12ver is fairly complex. Works much better with the lows to one amp and the highs to a separate amp with some overdrive.
That is why you see the 12vers with two or three outputs....more control running the neck PUP to an amp and the bridge PUP(s) to the other amp. If you have a single output, you will be running that full range signal to a splitter box and then to two amps.
I've been using an active 2-way biamp setup since around 1979, and it helps with the 12ver, but I got a chance to use it through a Fuchs Bruiser amp and a 3-way passive cabinet, and what a difference a HF tweeter makes.
