BOOGIE Mark II Users?
Is $1000 too much for a green stripe head? I've always wanted to try a Mesa Boogie Mark but have been scared off by the reputation for its loudness. I'm guessing the 25watt mode shouldn't get the neighbors too riled up.
https://reverb.com/item/6418762-mesa-boogie-mark-iii-head-green-stripe-simul-class-25w-85w-monster-tone-black
I have had a lot of fun with various Mark series amps. For some reason, I seemed to like the various IIs more then the IIIs, but that is probably just me.
One thing to ponder.....You may well be able to pick up a Mark V head for not a lot more than that. In addition to having a newer amp that should have less of the effects of age, you would have an amp with multiple power settings (10/45/90 watts) for each of the three discrete channels (each of which also has 3 different modes). Not to mention a footswitchable EQ function (presettable for each channel) and solo/boost function. It would give you a good deal more versatility. And arguably has "all the classic Mesa tones". And, unlike many earlier Mark versions, no need to share tone controls between "channels".
FWIW,  I found a Mark V locally for $1500, but that was for a combo with the optional (added cost) cabinet and grill.
Hahahahahahaaaaaaah! Don't kid yerself, kid! 25w will still be crushingly loud when you rev it up to its sweet spot.
And, yes, $1k is a good price for a MkIII with all of those features. Make him an offer and see if he'll actually do it for $1k, shipping included.
Jeff's opinions carry some weight so I was hoping the Green Stripe might be a possibility, but now I'm  back to being scared off by the loudness! Those Mark Vs are very appealing, I like the modern connectivity and options, those and the Petrucci version are looking like the most likely options now.
Yep, Jeffro knows his Boogs. Don't let the loudness scare you off. You can certainly get a great sound at living room volumes, though you might want to boost the front end with a OD pedal or some such. I just meant that they really start to get that saturation when you open them up on the master volume.
You should get the amp! If it's not your thing, you can always move it. Consider the Mk5/25, too. They can get hella loud, but sound GREAT on the 10w setting.
In real world terms, 25W amps are plenty loud for most band situations. My Splawn combo really starts to open up at about half, and that's about as far as I can push it without being stupid. I'm thinking of bringing my Astroverb 16 head home and getting a Mk5/25 for the S.F. practice pad. I think they are the best value in a low-wattage, high gain head out there.
Thanks.... I like the idea of lower wattage in the 25s but wasn't sure about the EL84s, seems like it wouldn't sound like the classic Boogie with those tubes. (but I'm totally guessing on that )
I put a Xotic BB Preamp set as a dirty boost more so than a Tube Screamer/OD thing if I'm trying to get stun gun tone out of the Boogie's gain channel at house/conversation volumes. The BB adds harmonic liveliness and the touch/hands thing you would typically get at high volumes. And the amp sounds incredible regardless of which wattage mode it's in. Truth be told, the 25/85 watt thing is more voicing (British versus American) than it is a volume thing. The BB Preamp works wonders on either mode at low volumes - my BB stays near my amp at all times. And that fucker can get LOUD as all hell in either mode. As for low end/high end at different volumes, that EQ is perfect for sweetening things on a case-by-case basis.
Great info, thx! So now I'm back to considering this green stripe.  B) . The cab condition doesn't matter, if I like it I plan on building a new head cab with some nice wood and classic wicker grill.
I have owned a bunch of different Mesa amps over the years Studio 22+, DC-3, MKIV, Lone Star, Blue Angel.  If you enjoy twiddling knobs to get "your sound"  out of it, you can do it, especially the MKIV.  its all about patience, keeping track of your knob settings.  Remember, your guitar knobs are in that signal path. An LP or a Studio will require different settings than a Strat orTele
Start with the knob setting examples in the user manual.
I'd recommend getting one of the DC models or Lonestar models. Why?   Separate dedicated knobs for each channel. No push/pull knob sharing between channels, its maddening, pull your hair out, throbbing forehead vein, maddening.
Document your knob settings, they are very, very sensitive.  For example 3 to 4 on any knob can cause a huge diff.  If you like a certain knob at 7½ document it, not 7 or 8, 7½ .   All the pots are quite interactive.   I got lucky,  The sample settings in the manual required very little tweaking  to get what I wanted out of the MarkIV.  The DC-3 was easy.  2 channels, all separate knobs.  No push/pull sharing.  The footswitchable,  5-slider is very cool.  You can use it as a boost for channel 1 or channel 2 or an EQ for a Strat or as EQ for a Hamer Studio.
Its kjnda obvious, my favorite was the DC-3,  I know,  i know, "I need more power than 30w bro!" Perhaps you do.  DC-5 is 50W.  DC-10 is 100W.  When are you playing Wembley?  Mesa power ratings are diff than any other amp brand I've played thru.  Don't be fooled by numbers, 30w of Mesa is louder than 45w of Fender, 50w of Marshall.
Just MHO.  YMMV
caddie
I have a iic+ and it's the touch sensitivity and response  where the magic resides.  There have been alot of good things said so far, but there is one thing OP said that about 4 gain stages that makes things difficult for people.  Volume 1, lead drive, lead master, then master 1.  Really if you are using it as a two channel amp then you don't want to think of it as four gain stages.  You need to think of the lead master as a volume balance knob between the clean channel and the lead channel.
When using the amp as a  two channel amp. Set your clean volume with volume 1 and  master 1.  Set your lead sound with vol 1 and lead drive and then use the lead master to balance the volumes of the two different channels.
If you are using it as a single channel lead amp then you can think of it as a three stage lead channel (vol 1, lead drive, lead master) with an added  master volume control at the end of the chain.
The difficulty lies in setting the vol 1 control so it works for both lead and clean.  And the other more difficult problem, and which  is the achilles heal of this amp, is balancing the EQ for both clean and lead settings.  The newer amps all have separate eq controls for each channel which fixes this problem.
Really I think this is one of the best sounding high wattage amps I have ever played.  You can get incredibly sweet clean sounds if you set it right and the most incredible lead tones.  But trying to do both at once is problematic.  But it can do amazing things and is incredibly versatile with no compromises in quality of tone,  if you just use it one channel at a time and learn how to set it.  Believe it or not, to me mine sounds better clean than the blackface twin I've had for 25 years.  But if I get that tone I won't be able to use the lead channel the way I want without changing the setting.  Yes this is a two channel amp but in a way it helps to not think of it as a channel switching amp but a very versatile amp.
Here are the setting for the mark iic that boogie released.  I know you have a mark iib , but I hope this can steer you into the right direction.
Did someone say MK IIB? One  (60 watt combo) is listed locally with EVM that appears to be in great shape and  only $800. All else equal, I'd prefer the Simul-Class, but seems like a very good price.......A new EVM alone will cost you at least $265.
https://portland.craigslist.org/mlt/msg/d/mesa-mark-iib-1x12-evm-12l/6289851025.html
Just to derail slightly IF you run into the Mesa Quad Preamp (and it has an intact footswitch) seriously consider it. It is, in essence, both an Mk IIC+ and a MKIII in one chassis, so you deal with the issue of balancing rhythm and lead by having 2 flavors of each. Seem to be hard to find anymore. And they ARE the rack mount stuff, with an implication you pick up a stereo power amp. The 2:Fifty is a very good match, the 2:Ninety even better. The latter has 90 watts of Simul-Class power per side, as well as "preamp" tubes inside the power amp that allow other footswitchable functions (half power, "deep" and "modern". Running that sucker through a pair of the "half back" type cabinets (EVM/Thiele below, V-30 semi open above) was my weapon of choice for a  good long while. A real monster----EIGHT Freakin' 6L6s!....I am going to have to break that beast outta the vault for another spin......
http://mesaboogie.com/media/User Manuals/Quad Preamp.pdf
Hmmmm, I already have a rack setup with a Peavey 50/50 pushing two 112 cabs loaded with an EVM and an EVM-esque speakers,,,
This seems like a good price too,
https://reverb.com/item/6480995-mesa-boogie-quad-preamp-w-footswitch
This has a power amp that comes with
https://reverb.com/item/6127250-mesa-boogie-quad-preamp-simul-class-stereo-295-power-amp-1987-black
Worth consideration.....A couple thoughts. The Quad (that era) was MADE to work with the 295 power amp. It is not nearly the equal of the (later) 2:Ninety, but the only thing wrong with it (other than possible age issues) is that it is much bigger than the 2:90 and not quite as versatile.But expect to pay much more for the newer power amp. I DID, at one time, use a Mesa Pre with the Peavey 50/50 and it worked well for me. You would do fine without the Mesa amp.
The other thought is that the second ad does not appear to show or state that the footswitch is included and fully functional. There IS a non-working link that MAY be intended to show it. It is not uncommon for them to come up missing, esp if a person has been touring with it. NOT having one is a big deal, IMO. You can control it with another form of controller (I never had a need to try the MIDI). It is very nice to be able to not only select any of the 4 presets with a stomp, but also either of the preset EQ settings. In effect, you get TWELVE different tones without further tweaking of knobs. And that is not to mention the "secret" way to get BOTH channels at once and blend them.
A MKIIb was the house amp at the Trump Castle in Atlantic Beach NJ in the 80's when I used to play there six weeks at a time. I hated that amp, I live in the in between zone, not clean/not dirty. That amp would do ultra clean and high gain, very little in between in there. I fought with the thing the whole time I used it. Trying to adjust it in small increments never seemed to work, turn down the volume of your guitar with the gain up it sounded like ass. It would go from one extreme to the other.  Not an amp for me, I'm a simple  one or two channel guy with a few pedals for more gain.
Cool Beans
Gene
