Because shell (assuming it's actually real MOP or abalone) is non-porous, it's most often affixed with either cyanoacrylate (superglue) or an epoxy. I don't know what Hamer was using for inlay adhesive, so can't advise on the right chemicals to free it up, but if it isn't a shrunken piece of plastic, like an old Gibson trapezoid, removing it without damage to it or the cavity edges will be tough. I successfully did a trapezoid removal/reglue by drilling a tiny hole at a slight angle next to the inlay to allow the solvent (acetone worked in that case) to penetrate and give me a spot to pop it up from without touching the edge of the wood channel. It's important to give the whole perimeter of the inlay/fingerboard surface acetone, too, so you don't end up tearing up wood grain around the edge when the bottom releases and you try to pop it up. Thankfully, it was in ebony, like yours, so easy to fill and hide that pin hole later on with a bit of ebony dust mixed with glue and a small plug at the surface.
That said, it's best to take very careful tracings and rubbings of the inlay first, just to make sure you have an accurate template to cut a replacement if it cracks in removal. Superglue can be uncooperative and epoxy virtually impossible, so be prepared for it to fight you. The wood channel is harder to fix if you mangle it than cutting a new piece of shell if it cracks, but prep, patience and a steady hand are the most important tools for this anxiety-inducing task.
Most inlay material is between 1/32" (0.03125) and 1/16" (0.0625) thick. 0.050" is the most common size for genuine solid shell blanks, and my guess is that's how thick it will be.
