P90 and Treble Bypass Mod PSA
threehole
Member
I have a Monaco III. Stock SD p90s are what everyone says, hot, thick sounding, I see why people love 'em and why they hate 'em. I leaned toward the latter as I wanted nicer clean sounds. Some say the M3 is like a strat on steroids, I suppose so, if the strat was completely roided out and pumped up and was almost unrecognizable verson of its former self. Like Mickey Rourke.
I grabbed a set of p90 mount TV Jones Filtertrons and dropped them in. I preferred the guitar with them, especially the classic+ in the bridge. I did not like the treble loss when using the volume control however. Apparently a common thing with filtertrons. I looked up the TV Jones treble bypass mod, and installed that in the Monaco, which was a hassle as there is no back cavity control cover. Fixed the issue.
I considered selling the guitar and reinstalled the stock pickups. No way was I pulling that treble bypass circuit, too much trouble to get in and likely some to get out. Plugged in and started playing, yup, all the nice stuff I remembered about those pickups, but also the annoying stuff too. But then I rolled back the volume knob...
With these pickups, that circuit acts as a low mids control, as you back off the volume, all the chime stays, and the bottom starts to thin out, much more so than with the Filtertrons. The volume does not change much as you roll back to about 4 or so. I was getting real stratty sounds, and Tele sounds (I rewired the 5 way so that one of the positions gets the bridge and neck combo). Really versatile now, and I can crank it up to get that thick p90 thing any time I want.
If anyone is dissatisfied with their stock Seymour Duncan p90s, give this a shot, you might be surprised.
AKA treble bleed circuit (although treble seems more accurate). Many manufacturers include them stock on their guitars (like Suhr and PRS). IME, wiring the guitar 50's-style helps retain treble as the volume is turned down as well. I've converted a couple guitars to 50's style wiring, but never installed a treble bypass circuit myself. Yet. /emoticons/default_biggrin.png
Austin
