Sanding down a neck and then...
TheDan
Member
I'm currently restoring an old Chap that has seen plenty of action and is in a quite dismal state. Especially the neck has gotten it pretty good, lots of dents, scratches, the whole bit. So I figured if I sand down the neck I should be able to get rid of most of them plus bring out that beautiful 3 piece maple neck. Now to my surprise there is a thick coat of some brown paste or something under the paint that is quite a b**ch to get off. Does anybody know what that could be and why it was put on?
sealer, primer. Primer for the used to be, what was left of it, pearl finish on it.
Use a chemical stripper or heat to get up the finish if you can.  Steam out the dents.  Sanding can get weird results.
