TC Electronics - G System
coolfeel
New member
Supporter
I have been wanting to get a unit that provides high quality functionality WITHOUT sucking the life out of my tone.
So far, I like what I have read and heard about this unit...
Who has owned or has experience with this unit and can provide some info?
The bassist in my band uses one with his guitar setup when he does guitar stuff with others. He's a total gearhead tone junkie and loves his. He keeps trying to get me to buy one, but I'm happy with my TC Nova System.
I will caution you that TC Electronic seems to apply a logic to their user interfaces that requires some deep manual reading and a lot of patience. The delays and such in the G System are allegedly the same as on the Nova System, and if so it is worth the work, as i LOVE mine.
I will be honest, I am very lazy when it comes to electronics - I can sit for a few minutes and noodle around, or tweak some pre-programmed sounds, but I would get frustrated if I had to do too much to find those "right" sounds.
I have an Xotic BB preamp that I sometimes hook up to my Shiva and got frustrated with it until DavidB came down and dialed in a killer tone on it. I probably shouldnt admit to that...lol
way too many opinions here~
http://www.hugeracksinc.com/forum/index.php
but, may get you closer in your own.
Most rack stuff is going to be "Deep in to it" that do not suck you tone.
the cheaper lexicon stuff is easy as well as some other stuff,
But, the top shelf stuff is going to need a little more time into it to get what you want out of it.
I had one and could not get rid of ground loop hum when using it in the four cable setup. The software editor was cool but I HATED programming it manually. If you are even half as lazy as you claim pass. It is built like a fucking tank though.
A hum issue? Wow, that concerns me as I have the older type looping on my Shiva - its the first year model. /emoticons/default_smile.png
Is there a way around the hum issue?
It's fine if you just run it in the fx loop. It gets wierd when you hook it up via the 4 cable system so you can run stuff like compressors, phasers, wahs, before the preamp where they sound best. Some folks beat the ground loops with balanced cables and Ebtech Hum Eliminators but I never had much luck. If the BB was a bit much you'll hate the G System. I have a G Sharp for sale /emoticons/default_blink.png .
Stike, how close are you to Charlotte? Kim Keller mentioned your name as someone who might be able to assist me with a possible restoration of my 86 Chaparral???
I bought one. Didn't like it. It really effected my signal path. I tried all every way from Sunday to hook it up. Before the pre-amp, loop, 4 cable method. It really colored my signal path to the point that I returned it. It just sucked some of the fullness and girth, compared to a direct cable connection. Sure, some non true-bypass pedals will do that too, but every time I would compare it without the G, direct sounded so much better. And for the cost of it, it should have been pristine.
Maybe some guys don't mind that tonal change for all the efx they get, but I thought it was too much for me.
On the positive side, I totally dug the midi switching. You can program the G to change your amps's channels along with the preset for your effects. That was awesome with my 4-channel Egnater Mod 50 head. If the tone was better, It would have been the bomb.
I've used mine with my Jubilee for years (four cable method), and currently use it with a Roland VG-99 in the insert. If you aren't into programming, there are plenty of presets to use as starting points.
I've never had any hum issues, even when I was running a Rat in one loop, a Roland JV-5080 in the next, a Vox Tonelab in the third, and the Marshall's preamp in the insert.
Unlike most multi effects, it has NO gain effects - I've never really needed much (the Rat was just a slight boost), and I hardly ever used it. They now offer a separate Nova Drive, which can be programmed from within the G-System.
I don't like to use stomp boxes (ridiculous complicated multi MIDI controlled rigs are not the same LOL), and my Rat didn't suffer from the loop, so I can't speak to that issue.
It is built like a tank (there is a TC video showing the pedal section actually being run over by a tank, and it still worked /emoticons/default_smile.png
No hum issues with mine, either, but I've never tried the four-cable method - so far I've just run it in front of the amp. I haven't noticed any major tone coloration, either.
There's a lot in there, for sure, and you could probably spend a couple weeks just setting up sounds. But there are also a lot of presets that are pretty usable right out of the box. I love being able to put additional pedals in the loops of the G-System.
Alan
I have probably played 100 shows with a Shiva/G-System setup. I have a real love/hate relationship with it. Its integrated nature makes a lot of things easy and simple.
However:
In general, there is not enough headroom on the inputs. I have to put the input gain below unity on my Les Paul with '57 humbuckers (not exactly screaming high-output pickups) in order to avoid clipping the input D/A. As a result, I now run my guitar directly into the Loop 1 return, bypassing the entire front end digital section. This works for me since I prefer an external compressor and wah, and don't need all four switching loops.
The headroom on the back end has similar problems. With my Shiva, I have to use a line-level shifter to pad the loop send signal way down, and I still have to run the channel volumes (which control loop send level at the amp) really low to avoid clipping the G-system's back end input.
I have had some hum problems, but the aforementioned line-level shifter is a transformer isolation unit which also eliminates ground loops, so that is a solved problem for me. On my Fryette Sig:X, I have had no hum problems without an isolator (and no loop signal level issues either).
As you can see, I have made some compromises to get this system to work in my case. Why go to all the trouble? Because there is no other way I can get the same functionality with any other unit at this price ($850 used in my case) and with only a single rack space. A similar setup with a G-Major, foot controller, and loop/control switchers would cost double and require additional rack space that I have no desire to haul.
However:
Thank you for the input, your situation seems close to what I might have to deal with if I go with a G System.
Do you have an older Shiva with the older effects loop? My Shiva is the first year series with the old loop which I hear can be fickle.
Thanks everyone for your feedback! If anyone else has additional feedback I would love to hear it.
I have an older, silver-back EL34 Shiva which requires the special cable for the effects loop. In this case, the line-level shifter replaces the signal pad cable.
