Thoughts on T-62
dobieboy
New member
Hi All;  I'm in the process of looking for a Strat-type guitar and would like to consider a T 62.. I've seen pics of one in Seafoam Green that would fit the bill, what are your thoughts?  Thanks in advance!
Great guitars. Mine has a medium/slim neck. On the wide side. I love it. From what I understand most of the T62 have this type of neck (beautiful birds eye maple by the way). The only negative thing I've heard about the T62 is from players who love really fat necks.
Tone wise they sound like a strat should. And they are super comfortable due to the body size. The ABM tremolo is awesome. But it can make the guitar a little bright if set to floating. I messed with the setup on mine and have the tremolo block set to have contact with the body through a small piece of wood glued in to the routing. Gives the guitar the vintage feel and body to the tone, that I am after.
The stock Duncans, alnico II's, are just right for this guitar, to tame the brightness. I changed them for Antiquity Texas Heat A2 strat pups. Sound similar, but a little livelier.
The T62 does not have a tone control. I roll the volume off just slightly which gives a similar effect as turning down the tone knob. The active boost circuit can be set to boost the mids, giving the guitar more of a humbucker feeling. Or P90ish tone. Or whatever, it's versatile but works mostly for overdriven tones. For clean it colours the tone in a way that I usually don't like.
The T62 holds the same build quality and tones as a Suhr, Anderson, Tyler or Fender Custom Shop. Hamer's finest bolt on model.
I have the T62 in surf green with the matching headstock.  Very comfortable.  Mine was a barn find, literally.  It came from a barn in upstate NY and looked like crap.  I cleaned it up, had it setup at Philtone, and its great.  You cannot go wrong with one.  Good hunting.
Thanks !!
