Reverse the ground and the hot on either pickup.I have a 2 mini hum pickup guitar with a tele type pickup selector
It has 2 vol no tone.
I put in a different bridge pup, and now when both pups are on its out of phase. Don't want that. Can anyone show a diagram of how it should be wired properly? Thank you
Not trying to hijack, but Josh, could you explain about this a little if you can.Could be magnetism issue as well, which happens more often with pickups sourced from off-shore manufacturers. Use a compass for mag check.
Thanks, I've never heard or seen that talked about. Appreciate it!There's a standard with humbuckers regarding magnet polarity/orientation in the pickup; "South" polarity is typically on the coil that is tied to ground, and the North polarity engages the coil wired as hot regarding the pickup output leads. If the magnet was accidentally installed with the polarity switched there, the pickup will then be out of phase when combined with other pickups.
Oh, man... this is a real thing! I made this mistake once too, a long time ago. An "early days" mistake. It's more common with import pickup manufacturers, a real thing, and yah, it happens.Thanks, I've never heard or seen that talked about. Appreciate it!
